It is currently Mon Jul 28, 2025 7:12 pm
PostPosted: Thu Apr 28, 2016 10:21 pm
Whats best to use to flush an engine in unknown condition,
it is not driveable/unknown/ it could be seized?
Is diesel or CRC/WD40 possible to use in a mini engine?
PostPosted: Fri Apr 29, 2016 7:41 am
First check the oil, if it looks black & sludgy, change it and the filter first.
Next, pull the spark plugs out, check if engine can turn over by hand. If so, squirt a little engine oil into each cylinder.
If not, I would pull the head off for a look.
If standing for more than 6 months I would prime the oil pump before trying to start it:
Remove oil pipe banjo bolt from block,
squirt motor oil into the block until hole is full,
with 4th gear engaged, push car backwards for 2 revolutions of the fan,
squirt more oil in, refit bolt but leave 1 turn loose to let air out.
Select neutral.
Crank engine for no more than 20 secs with plugs out. If oil flows out around the bolt, good news- you have oil pressure, tighten it up.
If it just gives 1 burp (what oil you put in) and no oil flow, I am sorry but the oil pickup strainer is plugged with sludge. Engine strip time.... :(
PostPosted: Fri Apr 29, 2016 3:49 pm
No oil is in engine or gearbox/sump.
It has been sitting for more than six months, it could have been years,
the engine flush I have looked at, appears to want the engine running and run but as stated it has been sitting for a long time.
I believe I need to lubricate bores and rings as you stated,
I have heard of people using diesel to flush, but unsure.
I might try oil with millilitres of engine flush,
I have not heard of anything else/product to clear sludge from gearbox pickup/strainer,
this is why I suggested diesel, but unsure if diesel will damage bearings and seals in gearbox or piston rings/bores in the engine?
PostPosted: Fri Apr 29, 2016 4:17 pm
Forget engine flush, fill with 20w50 oil then follow what I said above.
PostPosted: Fri Apr 29, 2016 5:18 pm
I've had good results using ATF in the spark plug holes & letting sit for a week for so after Dr's advice has been carried out to help free up stuck pistons but if it's to that point a rebuild will more than likely be needed.
Brad
During the day I work on English designed cars & on my own time I work on English designed cars....
