It is currently Tue Jul 29, 2025 12:37 am
PostPosted: Wed Apr 27, 2016 6:32 pm
Does anyone know where to find the correct circlips that fit both sides of the idler gear bearing in the gearbox (early, small shaft - approx 1 inch diam)? The old ones were a bit "limp" in their grooves so I bought 2 new ones from a bearing supplier. These are a good fit but their shape around the ears (where the 2 holes are) is too big and come really close to the gear shaft.
Mini Spares photo shows a different shape to their circlip 51K3565 but are out of stock. Noone in Aust. seems to stock them either.
Does anyone know where to find these circlips? Or just grind a clearance on the ones I have?
PostPosted: Wed Apr 27, 2016 7:58 pm
Grind the ones you have.
Btw you only really need the inner one. Push the bearing right in against it. So the 2 bearings are furthest apart for best shaft support.
PostPosted: Wed Apr 27, 2016 8:09 pm
Ive been robbing them out of old cases :)
PostPosted: Thu Apr 28, 2016 9:53 am
Looks like "grinding".
Thanks all.
PostPosted: Thu Apr 28, 2016 10:14 am
I had a quick search on the part number and came up with some OS suppliers:
http://www.leacyclassics.com/51k3565.html
http://www.somerfordmini.co.uk/eshop/in ... s_id=12545
PostPosted: Thu Apr 28, 2016 7:10 pm
Thanks for very much for your efforts.
I ended up using the generic circlips with the ears filed down with a diamond file. The circlips that came out of the box were undersized for the groove but had better clearance around the ears.
I tried the MiniMan's method of robbing old boxes but that circlip was also lose in the groove.
Did what Dr Kev said about pushing bearing onto the back circlip. Stops it moving, too.
Finally finished measuring the clearance of the idler thrust washers and getting 4 thou clearance on the the idler gear.
Thanks all,
Bill
Users browsing this forum: Bing [Bot] and 80 guests
