https://ausmini.com/forums/
Mini disc brake conversion.
https://ausmini.com/forums/viewtopic.php?f=2&t=92477
Author:  Budgiedagreat [ Mon Apr 25, 2016 2:14 pm ]
Post subject:  Mini disc brake conversion.
I'm converting the front end to disc but do t know what I should go for, thinking of later down the track doing a vtech conversion so want something powerful..
Any suggestions would be appreciated.
Regards Michael
Author:  zulu_warrior1976 [ Mon Apr 25, 2016 3:05 pm ]
Post subject:  Re: Mini disc brake conversion.
Something 8.4 at least.
I have heard of a camira conversion but they're not great as The Dr mentions.
Have you trolled through the site?
There's sure to be something in there.
Maybe look at Traveller R - Turbo orangies brother. That's a vtec conversion and brake upgrade.
Author:  simon k [ Mon Apr 25, 2016 8:23 pm ]
depends what wheels you want to use, if you're OK with 12", go with 8.4" mini discs. Later on you can upgrade them to Metro Turbo vented, or with the various 4 and 6 pot alloy calipers
I'd stay away from anything from another make... there are so many good off-the-shelf options to bother with it
Author:  Harley [ Mon Apr 25, 2016 8:27 pm ]
Put the biggest brakes you can on the car for the wheel size you're running.
Author:  drmini in aust [ Mon Apr 25, 2016 11:07 pm ]
The only set of Camira brakes I have seen on a Mini, the caliper mounting plates were welded onto the Mini drum swivel hubs.
This is wrong for 2 reasons:
1. Welding of suspension parts is only allowed by the manufacturer.
2. The swivel hubs are grey cast iron, the brackets are steel. Arc welding (MIG or stick) here can crack the cast iron.
Author:  Budgiedagreat [ Tue Apr 26, 2016 10:33 am ]
I'm thinking of going the metro turbo 8.4 brakes what's the minimum wheel size you can run with them 12x5?
Author:  simon k [ Tue Apr 26, 2016 12:30 pm ]
yep, though you could probably go 12x4.5 if you really wanted...
Author:  Budgiedagreat [ Tue Apr 26, 2016 12:32 pm ]
I like the wide look and the wide flares so metro brake setup, might go the steering rack for 13" wheels just in case I go bigger
Author:  timmy201 [ Tue Apr 26, 2016 12:43 pm ]
Depending on what state you are in they'll have different requirements for brakes when you do an engine swap. Might be worth checking that out now to save yourself a headache down the track?
Author:  Budgiedagreat [ Tue Apr 26, 2016 2:48 pm ]
I'm in NSW and will register it here I'm thinking of getting an engineers report For the front end to save the trouble of rego
