Mini rod change anti leak kit removal https://ausmini.com/forums/viewtopic.php?f=2&t=92474 |
Author: | kiwiinwgtn [ Sun Apr 24, 2016 10:47 pm ] |
Post subject: | Mini rod change anti leak kit removal |
Hi My mini rod change seal kit is worn and is leaking oil. How do i get the old sleeve out with out taking off the diff housing with engine in car. any one got any tricks. pic off offending item is below. my new one has two threads tapped in it. Thanks Kiwiinwgtn http://trademe.tmcdn.co.nz/photoserver/ ... 071791.jpg |
Author: | gtogreen1969 [ Sun Apr 24, 2016 11:03 pm ] |
Post subject: | Re: Mini rod change anti leak kit removal |
I tried the el-cheepo brand before I saw the one that "TheMiniMan" sells. It only lasted a few months. I managed to get the sleeve out by drilling 2mm drill bits into opposite sides and leaving them in there, then pulling on the drill bits with pliers. Not much room in there and you have to make sure you don't slip and scratch the sealing surface. I ended up going with 2 seals because I had them in my spares bin and it stopped the leak. |
Author: | TheMiniMan [ Mon Apr 25, 2016 9:15 am ] |
my kits (the latest ones) already have 2x drilled & threaded holes to screw into ![]() Matt |
Author: | 1275LS [ Mon Apr 25, 2016 9:25 pm ] |
My car has been running Matts kit since December 2014 with no leaks. Happy Wifey... Thanks Matt. |
Author: | kiwiinwgtn [ Mon Apr 25, 2016 9:31 pm ] |
TheMiniMan wrote: my kits (the latest ones) already have 2x drilled & threaded holes to screw into ![]() Matt its your one i am swapping it out with. ![]() |
