https://ausmini.com/forums/
Pushrod assembly from a Lockheed Brake Servo
https://ausmini.com/forums/viewtopic.php?f=2&t=92449
Author:  miniresto [ Fri Apr 22, 2016 8:38 am ]
Post subject:  Pushrod assembly from a Lockheed Brake Servo
Could anyone confirm how the pushrod assembly from a Lockheed Brake Servo (as fitted to the MK1 S) comes apart. I need to replace the shaft itself and am guessing that is crimped in at the bottom where the indent marks are at the bottom as shown in the pic.
Author:  miniresto [ Sat Apr 23, 2016 5:15 pm ]
Post subject:  Re: Pushrod assembly from a Lockheed Brake Servo
Problem solved. It is crimped in.
Now have it apart and can now get new rods machined.
Author:  Mick [ Sat Apr 23, 2016 7:00 pm ]
You can buy these new from J&L Spares in the UK at about 30 dollars (exchange). http://www.jlspares.com/sealkits1.htm
I re-chromed my pushrod, and then drilled and pinned the joint as a home fix.
Author:  miniresto [ Sat Apr 23, 2016 7:47 pm ]
Thanks for the info Mick. I will pick a couple up from them when I am over in the UK in July.
Author:  Bill B [ Sat Apr 23, 2016 9:15 pm ]
It might be worth considering having them made from stainless rod. The chrome always flakes, rusts and cuts the seal.
I have had some machined down to size at a local engineer.
Author:  drmini in aust [ Sat Apr 23, 2016 9:48 pm ]
If rechroming the rod you want 'hard chrome', not decorative. A problem with SS is it is way softer than chrome, it does not wear nearly as well.
