Disc brake master cylinder https://ausmini.com/forums/viewtopic.php?f=2&t=92438 |
Author: | TK [ Wed Apr 20, 2016 6:32 pm ] |
Post subject: | Disc brake master cylinder |
I have recently purchased a reco master cylinder. I have heard that I need to take it apart and remove the top inner valve so it can be used with disc brakes. Is this correct? What does this valve look like? thanks |
Author: | goodie [ Wed Apr 20, 2016 7:38 pm ] |
Post subject: | Re: Disc brake master cylinder |
They're not getting it mixed up with a Clutch Master Cylinder are they ? |
Author: | TheMiniMan [ Wed Apr 20, 2016 9:14 pm ] |
I would make sure its actually in there Not take it out |
Author: | RNY997 [ Thu Apr 21, 2016 9:27 am ] |
Removing it for disc brakes is correct. Its a line pressure retention valve for front drum brake cars. Disc brake calipers dont have any mechanism to release the pads from the disc other than disc runout and flex in the piston seals so pressure retention wont help this. Looks like a little rubber top hat pushed into the spring end at the outlet end. |
Author: | TK [ Thu Apr 21, 2016 3:22 pm ] |
thank you. |
Author: | TheMiniMan [ Fri Apr 22, 2016 10:03 am ] |
minis still have drum rear brakes,,, if you run without that "Slow Return Valve" then as the rear shoes wear, the distance the shoes have to travel is quite far & your brake peddle will travel to the floor before it gets any pressure,,, release the peddle & the rear shoes return with the springs pulling them back home & upon the 2nd application of the brakes you will still find a very low brake peddle that valve is meant to be in there whether you have disc front or drums because you still have drum rears... without it you will not be able to pump up a peddle it is (However) detrimental to fit that valve into a clutch master cyl, because you really don`t want the clutch to be able to "Pump-up",,, if it does then you can easily break the lugs off the alloy clutch wok at the base of the clutch arm,,, or even worse (if you don`t have the "Anti-over-throw-nuts" fitted & adjusted correctly,,, you can break the bolts off the center main cap inside your engine make sure the valve "IS" in the brake master cyl !!!!!!!! make sure it`s "NOT" in the clutch master cyl !!!!!!!!!! simple as that |
Author: | winabbey [ Fri Apr 22, 2016 1:03 pm ] |
TheMiniMan wrote: ... simple as that What's happened to your usual "easy peasy" signoff? ![]() ![]() |
Author: | TheMiniMan [ Wed May 04, 2016 1:34 pm ] |
sorry, i was "In the moment" trying to get the point across that the "slow return valve" is still needed all the brake master cyls in minis should still have the "Slow Return Valve" definately not in a clutch master cyl tho,,, certainly not but definately yes in a brake master cyl easy-peasy ![]() |
Author: | TK [ Wed May 04, 2016 7:06 pm ] |
http://minisport.com.au/reconditioned-b ... 50-plastic I'll leave it in. |
Author: | slacko [ Thu May 05, 2016 9:09 am ] |
Question is not .75in bore for clutch and .70in bore for brake ? |
Author: | drmini in aust [ Thu May 05, 2016 9:42 am ] |
slacko wrote: Question is not .75in bore for clutch and .70in bore for brake ? Usually is yes. But 850 had 3/4" brake master, late 997 Cooper & 998 Cooper had 5/8" brake master. re clutches, 1970? on Minis with the Lockheed/PBR clutch MC (plastic reservoir) mostly had a .70" bore MC. Hardly moved enough oilz to work the clutch properly. Other Minis clutch MCs were .75". |
Author: | gtogreen1969 [ Thu May 05, 2016 11:38 am ] |
slacko wrote: Question is not .75in bore for clutch and .70in bore for brake ? Yes. The smaller diameter piston will give you more psi (best for brakes) and the larger piston will move more fluid (best for clutch) |
