997 Cooper voltage regulator wiring harness https://ausmini.com/forums/viewtopic.php?f=2&t=92437 |
Page 1 of 3 |
Author: | OnSafari [ Wed Apr 20, 2016 2:54 pm ] |
Post subject: | 997 Cooper voltage regulator wiring harness |
Putting my 997 together and i have a question regarding the regulator wiring, my new loom has the regulator wiring branching from the main harness at the firewall, it then has to run under the fuse box, seem odd to me??? Any pics of original spec setups? |
Author: | gtogreen1969 [ Wed Apr 20, 2016 4:02 pm ] |
Post subject: | Re: 997 Cooper voltage regulator wiring harness |
The only reason i can see why they would split the loom at the firewall is if the generator was mounted like the Cooper S. Is that a generic loom to fit both Cooper and Cooper S? |
Author: | DavidE [ Wed Apr 20, 2016 4:29 pm ] |
OnSafari wrote: Putting my 997 together and i have a question regarding the regulator wiring, my new loom has the regulator wiring branching from the main harness at the firewall, it then has to run under the fuse box, seem odd to me??? Any pics of original spec setups? Yes, but clarity is a real issue. Aren't those loose wires for the back end of the fuse block? The regulator wires should come from the harness after it emerges from the hole in the bracket adjacent to the regulator, so they attach directly to the terminals of the regulator. |
Author: | Goldbrocade_62 [ Wed Apr 20, 2016 4:44 pm ] |
I have my original 997 harness on the shelf will look soon |
Author: | OnSafari [ Wed Apr 20, 2016 5:06 pm ] |
Goldbrocade_62 wrote: I have my original 997 harness on the shelf will look soon Thanks |
Author: | OnSafari [ Wed Apr 20, 2016 5:08 pm ] |
gtogreen1969 wrote: The only reason i can see why they would split the loom at the firewall is if the generator was mounted like the Cooper S. Is that a generic loom to fit both Cooper and Cooper S? No from Vinwire and is supposed to be for 997 Cooper |
Author: | OnSafari [ Wed Apr 20, 2016 5:09 pm ] |
DavidE wrote: OnSafari wrote: Putting my 997 together and i have a question regarding the regulator wiring, my new loom has the regulator wiring branching from the main harness at the firewall, it then has to run under the fuse box, seem odd to me??? Any pics of original spec setups? Yes, but clarity is a real issue. Aren't those loose wires for the back end of the fuse block? The regulator wires should come from the harness after it emerges from the hole in the bracket adjacent to the regulator, so they attach directly to the terminals of the regulator. Yes, those loose wires are for the fuse block, I just havn't installed it yet. |
Author: | Goldbrocade_62 [ Wed Apr 20, 2016 5:27 pm ] |
Just checked would branch at the gusset not the bulkhead like the new one And the new one I put in it is correct to |
Author: | DavidE [ Wed Apr 20, 2016 6:06 pm ] |
OnSafari wrote: DavidE wrote: OnSafari wrote: Putting my 997 together and i have a question regarding the regulator wiring, my new loom has the regulator wiring branching from the main harness at the firewall, it then has to run under the fuse box, seem odd to me??? Any pics of original spec setups? Yes, but clarity is a real issue. Aren't those loose wires for the back end of the fuse block? The regulator wires should come from the harness after it emerges from the hole in the bracket adjacent to the regulator, so they attach directly to the terminals of the regulator. Yes, those loose wires are for the fuse block, I just havn't installed it yet. Where a the wires for the regulator, then? |
Author: | OnSafari [ Wed Apr 20, 2016 6:23 pm ] |
Quote: Where a the wires for the regulator, then? The second braided loom going through the gusset |
Author: | OnSafari [ Wed Apr 20, 2016 6:24 pm ] |
Goldbrocade_62 wrote: Just checked would branch at the gusset not the bulkhead like the new one And the new one I put in it is correct to Any chance of a picture? Looks like I will need to remove it and send back for modification. Cheers |
Author: | Convertible Mini [ Wed Apr 20, 2016 7:23 pm ] |
From the picture it seems to have a big harness loop behind the Gusset . I might be wrong but is the loom fitted correctly or does it need to go further foreward? |
Author: | Goldbrocade_62 [ Wed Apr 20, 2016 7:52 pm ] |
OnSafari wrote: Goldbrocade_62 wrote: Just checked would branch at the gusset not the bulkhead like the new one And the new one I put in it is correct to Any chance of a picture? Looks like I will need to remove it and send back for modification. Cheers Will get it tomorrow |
Author: | AJ [ Wed Apr 20, 2016 8:10 pm ] |
I got this one for my 997 Cooper , haven't put it in yet , will get a pic tomorrow http://www.somerfordmini.co.uk/eshop/in ... ts_id=4062 |
Author: | OnSafari [ Wed Apr 20, 2016 9:21 pm ] |
[youtube][/youtube] Convertible Mini wrote: From the picture it seems to have a big harness loop behind the Gusset . I might be wrong but is the loom fitted correctly or does it need to go further foreward? It's in the correct position, the earth wires are bolted to the gusset, and the fuse box wires are in the correct location, plus everything else lines up fine. |
Page 1 of 3 | All times are UTC + 10 hours |
