Leaking Oil Filter Housing Spin On https://ausmini.com/forums/viewtopic.php?f=2&t=92426 |
Author: | kiwiinwgtn [ Mon Apr 18, 2016 8:06 pm ] |
Post subject: | Leaking Oil Filter Housing Spin On |
My Oil filter housing the spin on type is leaking oil Its a 1300 land crab spin on filter housing. I have read that high reving minis can have problems. I have been driving it with passion. Its a 1360 modified engine etc. I have checked the housing for cracks etc, new gasket, its tight on the block, Wipex filter. any thoughts. |
Author: | drmini in aust [ Mon Apr 18, 2016 8:20 pm ] |
Post subject: | Re: Leaking Oil Filter Housing Spin On |
Is it the gasket flange, or a crack in the body? The stock spin on gasket is flimsy, I made my own. File the flange to ensure it's flat. |
Author: | kiwiinwgtn [ Mon Apr 18, 2016 8:28 pm ] |
Thanks Kev The gasket is of a decent quality. I did check if the flange was flat with a steel rule and some feeler guages and it looked fine. Theres not much too go wrong. It was in the engine bay fire I had so may be its warped a little. I may have to find another one and swap it out. It did happen after a reasonably hard run |
Author: | drmini in aust [ Mon Apr 18, 2016 9:15 pm ] |
I would file it to ensure it is flat. Even over tightening the bolts can bend it. The fire would maybe have warped it. |
