Australian Lock barrels https://ausmini.com/forums/viewtopic.php?f=2&t=92407 |
Author: | LeylandMiniPhil98 [ Sat Apr 16, 2016 1:10 pm ] |
Post subject: | Australian Lock barrels |
Hi all, i cant seem to figure out how to remove the lock barrels on my doors? Any helps appreciated, cheers. Sent from my SM-G925I using Tapatalk |
Author: | MiniBrad [ Sat Apr 16, 2016 2:25 pm ] |
Post subject: | Re: Australian Lock barrels |
The last clubman doors I pulled apart, I popped off the spring retainer that goes around the outer surface of the barrel with a small flat blade screwdriver & the barrel came out. Brad |
Author: | Goldbrocade_62 [ Sat Apr 16, 2016 2:28 pm ] |
MiniBrad wrote: The last clubman doors I pulled apart, I popped off the spring retainer that goes around the outer surface of the barrel with a small flat blade screwdriver & the barrel came out. Brad And disconnect the linkage too |
Author: | LeylandMiniPhil98 [ Sat Apr 16, 2016 2:34 pm ] |
Ive done that but i still cant get it out, ease it out with a BFH then i spose... Sent from my SM-G925I using Tapatalk |
Author: | LeylandMiniPhil98 [ Sat Apr 16, 2016 8:17 pm ] |
Yep, got em both out thanks guys. Turns out they were just stuck in there due to years of build up so the locks were a little siezed. I need to get new locks anyway as i dont have the key to them but they were already pretty dented and scratched... Sent from my SM-G925I using Tapatalk |
