Converting from rubber uni's to cooper S setup https://ausmini.com/forums/viewtopic.php?f=2&t=92387 |
Page 1 of 3 |
Author: | Minicooper4me [ Thu Apr 14, 2016 9:03 pm ] |
Post subject: | Converting from rubber uni's to cooper S setup |
I want to convert from rubber uni's on a 4 syncro box to the steel type as on Cooper S. Currently have 7.5 inch Cooper S disc brake setup with rubber uni's as per mini deluxe. Can it easily be done and what parts do I need to complete the conversion. Thanks in advance. |
Author: | simon k [ Thu Apr 14, 2016 9:15 pm ] |
Post subject: | Re: Converting from rubber uni's to cooper S setup |
other than the universals, you'll need the diff side covers - steel uni type has a smaller hole than for rubber unis and pot joints (if I remember correctly...) I reckon you're better off converting to pot joints, that's what I'm using on my S, though it's a bigger change because the driveshafts and diff output shafts need to change |
Author: | drmini in aust [ Thu Apr 14, 2016 9:22 pm ] |
You would also need Cooper S diff output shafts. Are different to rubber coupling ones. I agree with Simon, pot joints are an easier cheaper conversion. |
Author: | timmy201 [ Thu Apr 14, 2016 9:26 pm ] |
You need all these to convert from rubber universals. ![]() Only downside to pot joints is you need the driveshafts too. You can get a kit with all the parts from minikingdom http://minikingdomonline.com.au/product ... pot-joint/ If you're changing the diff output shafts you'd probably change the diff pin, bearings and planet gears while you are in there.. |
Author: | Minicooper4me [ Thu Apr 14, 2016 9:32 pm ] |
Thanks guys. I do have some pot joint parts but wasn't sure they would fit. Nead to go scrounging in the shed tomorrow to see what's there. great stuff. |
Author: | TheMiniMan [ Fri Apr 15, 2016 7:57 am ] |
motor out diff out swap inner axles & away you go |
Author: | gtogreen1969 [ Fri Apr 15, 2016 8:38 am ] |
TheMiniMan wrote: motor out diff out swap inner axles & away you go Easy peasy |
Author: | Goldbrocade_62 [ Fri Apr 15, 2016 8:42 am ] |
gtogreen1969 wrote: TheMiniMan wrote: motor out diff out swap inner axles & away you go Easy peasy Matt could do it in his sleep lol |
Author: | drmini in aust [ Fri Apr 15, 2016 10:03 am ] |
Easy peasy, IF the shafts come out of the CVs. I have had to cut a few CVs up to get the shafts. |
Author: | mooman10_0 [ Fri Apr 15, 2016 10:46 am ] |
I have a morris mini k out the back which has the exact setup as whats in the picture, did they come out with this or has someone added it? It is tucked out the back awaiting to be my 2017 project, lol! |
Author: | timmy201 [ Fri Apr 15, 2016 10:54 am ] |
The "Hardy Spicer" type universal joints were fitted to the Cooper S and the Minimatic. The rubber style were fitted to everything else up until the rod change boxes, which then changed to the pot joints. |
Author: | drmini in aust [ Fri Apr 15, 2016 10:55 am ] |
timmy201 wrote: The "Hardy Spicer" type universal joints were fitted to the Cooper S and the Minimatic. The rubber style were fitted to everything else up until the rod change boxes, which then changed to the pot joints. Some Mokes had Hardy Spicers too. |
Author: | timmy201 [ Fri Apr 15, 2016 11:04 am ] |
drmini in aust wrote: timmy201 wrote: The "Hardy Spicer" type universal joints were fitted to the Cooper S and the Minimatic. The rubber style were fitted to everything else up until the rod change boxes, which then changed to the pot joints. Some Mokes had Hardy Spicers too. Were they only fitted to a particular Moke model/timeframe? |
Author: | drmini in aust [ Fri Apr 15, 2016 11:25 am ] |
Early 70s. Before pot joints came in. |
Author: | mooman10_0 [ Fri Apr 15, 2016 11:56 am ] |
So worth keeping on if already in there im guessing? Benefits? Cheers, Steve |
Page 1 of 3 | All times are UTC + 10 hours |
