It is currently Tue Jul 29, 2025 6:17 am
 Post subject: WATER PUMP BYPASS HOSE
PostPosted: Wed Apr 13, 2016 4:49 pm
Just wondering how many of you guys run a blanked off bypass on your water pump
Will this improve cooling
1970 MK2 Cooper S
PostPosted: Wed Apr 13, 2016 5:49 pm
I had it blocked on one car. Made no difference to cooling, just better reliability. 1 less hose...
PostPosted: Wed Apr 13, 2016 7:50 pm
I've had it blocked off since 1998
PostPosted: Wed Apr 13, 2016 8:14 pm
Mine is gone, no issues at all. I did drill a hole in the thermostat as recommended though..
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Thu Apr 14, 2016 6:46 pm
I have blanked mine off, and removed the thermostat. I also fitted this blanking sleeve:
http://www.minispares.com/product/Class ... o%20search
