https://ausmini.com/forums/
Cooper s early mk1 right hand fuel tank vent pipe clips
https://ausmini.com/forums/viewtopic.php?f=2&t=92378
Author:  Tomtax [ Wed Apr 13, 2016 10:25 pm ]
Post subject:  Cooper s early mk1 right hand fuel tank vent pipe clips
Hi all
I was wondering if anyone out has any early mk1 S right hand fuel tank vent pipe clips (pre spot welded tags)
Pm me if you have any
Thanks
Author:  Freddo [ Fri Apr 15, 2016 8:03 am ]
Post subject:  Re: Cooper s early mk1 right hand fuel tank vent pipe clips
PM sent
Author:  IndigoBlueCooperS [ Fri May 06, 2016 9:13 pm ]
Anyone have the dimension & location for the two holes?
I have the clips but no holes for them.
Looks like 5/16 is the diameter but how far down from the underside of the parcel shelf are they located?
Author:  gtogreen1969 [ Fri May 06, 2016 9:34 pm ]
Here is a photo from Freddos resto. Yes they are a 5/16" hole.
Some more info here viewtopic.php?f=2&t=45465&hilit
This photo is from mmallecks resto.
Author:  Bubbacluby [ Sat May 07, 2016 2:57 pm ]
Im curious as to why you want to drill holes to make it as per early Cooper S?
Author:  gtogreen1969 [ Sat May 07, 2016 3:16 pm ]
It may be for the 1964 Buckle Monaco. Based on an 850 shell.
viewtopic.php?t=84505
Author:  IndigoBlueCooperS [ Sun May 08, 2016 9:59 pm ]
Yes, it is for the Monaco to secure the fuel tank vent tube. Bit more professional than using a couple of cable ties and will retain the classic look for a car built around 1966.
So, is anyone able to get a couple of dimensions?
