https://ausmini.com/forums/
how to break into any mini and start any round nose lol
https://ausmini.com/forums/viewtopic.php?f=2&t=92360
Author:  drjbeam [ Mon Apr 11, 2016 4:51 pm ]
Post subject:  how to break into any mini and start any round nose lol
Addison's has came across a fs key board with cut numbered keys
https://m.facebook.com/1458515547755207 ... ref=stream
Author:  TheMiniMan [ Mon Apr 11, 2016 5:37 pm ]
Post subject:  Re: how to break into any mini and start any round nose lol
we`ve had few of these boards ever since day-dot
& we still have them
Author:  Bubbacluby [ Mon Apr 11, 2016 5:47 pm ]
I went out to Jacks one day and didnt have a key for my doors. Jack had a keyboard, got a bunch from it and tried a few random ones and about the 5th one I got it.
Author:  drjbeam [ Mon Apr 11, 2016 6:25 pm ]
It would make a good wall hanger in a mans room
Author:  2lateagain [ Tue Apr 12, 2016 8:02 am ]
My son who is a locksmith told me when he was doing some work for me on a number of boot locks, that there were only 99 different combinations used across the mini range. This information came from his computer that is used to program the key cutting machine that will cut keys to virtually any vehicle that was sold in Australia in numbers and goes back many decades.
We found numbers stamped on the cylinder on the door locks and some on the square drive of the boot locks, when put into the computer the keys were cut spot on. I am beginning to believe him as I have found that since getting the boot locks working I now have found 1 door lock (with no key) for each of the boots locks that are keyed the same. The boot and door locks are not from the same vehicle as they have been sourced from where ever they were available. The two cars I have came with neither door nor boot locks.
Graham
Author:  timmy201 [ Tue Apr 12, 2016 8:12 am ]
I'd reckon about 90% of those keys would open my worn out key barrels anyway!
Not that the central dash ignition switch is hard to get the wires off anyway...
Author:  winabbey [ Tue Apr 12, 2016 3:30 pm ]
MKO and others sell key blanks. I think MKO also has a key cutter that will cut from a sample, not the computerised cutter mentioned above.
http://minikingdomonline.com.au/product ... fs-series/
Author:  rodmac [ Tue Apr 12, 2016 5:09 pm ]
Keys for classics can decode your key and give you its number from a good photo as well as cut keys to a code. Had this done for 2 of my GT's - one which had the number on an original key and one which did not have a number and was pretty worn. Both keys work perfectly.
Rod
Author:  lefty [ Tue Apr 12, 2016 7:24 pm ]
In my previous job I had a small master key to open filing cabinets, compactus and other assorted locks with similar keys. Was very handy, saved a whole bunch of keys. Then I found by accident it would fit all the locks on my previous Aussie CooperS, including the petrol cap. It got worse - it also opened the mailbox here at home (and a neighbour's but don't ask how I know). The magic key.
Author:  motodevo [ Tue Apr 12, 2016 9:34 pm ]
All said, if you need a key to break in or steal a roundnose mini, you're working too hard. Probably one of the easiest cars you open/start without a key
