It is currently Tue Jul 29, 2025 6:16 am
PostPosted: Fri Apr 08, 2016 10:14 am
Hello All,
I've recently put a mid 80s A+ 998 automatic in my old minimatic to replace the original A series. As the new engine had pot joints rather than the hardy spicers of my original powerunit, I bought 2 second hand driveshafts out of a 70's moke. However, when I put these in the car and drive it, it sounds "loose" like the balls are clicking about inside the Pot. After a bit of research, I've read that there was sometimes a bigger set of pots (and corresponding race/balls). Has anyone else had any issues like this? Would I better trying to track down a bigger race/cage or trying to remove the Pots and replace them with standard size?
Thanks
88 Rover 1.3i "Reggie"
99 Rover 1.3i “Grover”
17 Mini Clubman JCW “Noddy”
PostPosted: Fri Apr 08, 2016 11:56 am
reco ones from different suppliers often have larger pots & larger inner race & cage to suit
but the balls are still 21/32
i`ve found 4 different sizes (so far)
measure twice,,, fit once :-)
PostPosted: Fri Apr 08, 2016 12:32 pm
Ahhh! Thank you sir, I will keep looking then and take measurements.
PostPosted: Fri Apr 08, 2016 6:20 pm
But don't they come in sets???? ie a "pot joint"...
I'm assuming the diff output shaft anf the drive shaft have the same sized splines????
Cheers, Ian
PostPosted: Fri Apr 08, 2016 9:05 pm
There's a diameter difference of about 4mm between aussie clubby pot joints and rover ones.
I discovered this when I tried to put the rover inners into the aussie outers - and it wouldn't fit.
After finding some rover outer pot joints - I was back in business.
If you've done the other way I'd bet everything inside is knackered - so best to source a complete assembly.
PostPosted: Sat Apr 09, 2016 10:02 am
Hi Harley,
Yes I've the other way. Aussie inners into Rover outers. Its very noisy. I'll post up in the wanted section for rover driveshafts. Thanks for confirming my suspicions.
Cheers all!
