It is currently Tue Jul 29, 2025 12:35 am
PostPosted: Thu Apr 07, 2016 10:18 pm
I have a Flywheel where the timing mark is NOT adjacent to one of the 3 holes were the pressure plate can come though to fix the clutch plate too.
Where do I put my "A's"????
Looked in my books and I can't find it :( :(
PostPosted: Fri Apr 08, 2016 8:33 pm
We are surprised that we haven't got a response!
Is my question clear or a bit fuzzy?
PostPosted: Fri Apr 08, 2016 8:36 pm
Do you have a photo or 2 Pete.
PostPosted: Fri Apr 08, 2016 8:52 pm
This is the Fly wheel...Trying to find out were to line up the 2 "A" marks.
PostPosted: Fri Apr 08, 2016 9:01 pm
I'll have a look in the shed tomorrow Pete. In the meantime some knowlegible people may reply.
PostPosted: Fri Apr 08, 2016 10:02 pm
I bet someone has had the centre out of the flywheel and refitted it in the wrong position.
It looks 180deg out to me.
PostPosted: Fri Apr 08, 2016 10:16 pm
The Picture that we have posted, come from "The Scientific Publications Workshop Manual Series No64 Mini."
We will wait and see if other's have come across this?
PostPosted: Fri Apr 08, 2016 10:22 pm
Usually the slot in the flywheel is at the top when pistons 1 & 4 are at TDC.
The A mark on the backplate and the diaphragm go to that hole.
As I said in that pic the flywheel outer is fitted 180deg out if it is at TDC.
PostPosted: Sat Apr 09, 2016 11:25 am
With this Fly Wheel and others I have, moving the centre, will not change the casting of the fly wheel.
The TDC marks and the three holes for the pressure plate are fixed on the one plate.
I have fitted it as I think is right.
Thank you for your input.
PostPosted: Sat Apr 09, 2016 11:52 am
Mine looks exactly the same as your's Pete, but I can't see any A's on any component. Sorry I can't help too much.
I have a Haynes manual and it shows the A's matched up together just to the right of the TDC marks. My guess it is for balancing. Also when removing the flywheel I have always kept TDC to the top as i guess the big C clip behind the flywheel cant' fall out and jam up the removal. Not too sure about this deduction but I'm sure there will be some more experienced person along in a minute to correct me.
PostPosted: Sat Apr 09, 2016 2:21 pm
Since they got rid of the wet tail crank and its extra oil seal IN the flywheel in 1963, there is nothing for the C clip to hey caught in. But haynes etc have not caught up. :)
But yes I still set it to tdc anyway.
PostPosted: Sun Apr 10, 2016 9:59 pm
A pic from an old workshop manual I have...
PostPosted: Sun Apr 10, 2016 10:14 pm
Hey Flapper, cleaned up my clutch components and I have found the "A"'s. Mine are to the left of TDC markings on the flywheel (ie. To the rear side of the engine). My engine is an 1098, not sure if these are different to 848 or 998.
PostPosted: Sun Apr 10, 2016 10:36 pm
[quote="Drewie"]A pic from an old workshop manual I have...
Thank you for your reply...BUT...Your Flywheel Picture is a different Flywheel to our Picture as the timing marks are in a different place.
PostPosted: Sun Apr 10, 2016 10:40 pm
You might not hear this very often....Good Boy :) :)
We have been told to look for "A"s on the Flywheel..Looked at 3, could find any "A"s
Users browsing this forum: Bing [Bot] and 86 guests
