Engine storage https://ausmini.com/forums/viewtopic.php?f=2&t=92324 |
Author: | lefty [ Thu Apr 07, 2016 9:59 pm ] |
Post subject: | Engine storage |
Hi: Done a search but can't see anything - if I have missed sorry. I need to store a complete power unit for a while, fully assembled including radiator. Any tips? Obviously fill the sump to the dipstick full mark - but what else? Fill the cooling system? Thank you |
Author: | Bubbacluby [ Thu Apr 07, 2016 10:22 pm ] |
Post subject: | Re: Engine storage |
Block all holes up to stop wasps making nests anywhere they can |
Author: | drmini in aust [ Fri Apr 08, 2016 7:52 am ] |
Put a strip of cardboard instead of a manifold gasket, if carbs are on it. Squirt some oil into all the spark plug holes then turn the motor over by hand for a turn or so. |
Author: | lefty [ Fri Apr 08, 2016 6:31 pm ] |
Thank you |
Author: | 1071 S [ Fri Apr 08, 2016 7:20 pm ] |
I would drain all the water... electrolytic action will continue if you don't.... ..and how much is .."a while"... ?? Fresh oil and clean antifreeze is fine for 4 or 5 years.. You can buy special "fogging" oil for long term storage. Cheers, Ian |
Author: | Minicooper4me [ Fri Apr 08, 2016 8:42 pm ] |
I could store it in my mini and give it a run now and then, just to help you out. |
