https://ausmini.com/forums/
Running on
https://ausmini.com/forums/viewtopic.php?f=2&t=92316
Author:  i got a mini [ Wed Apr 06, 2016 6:15 pm ]
Post subject:  Running on
Hey all having a problem with my car when I turn the ignition off it runs for a while then stops. Now I have used a gunson colour tune and it's spot on in mixture and timing is 5 deg at idle and still runs on what causes this any help would be appreciated thanks
Author:  MiniVLT [ Wed Apr 06, 2016 7:30 pm ]
Post subject:  Re: Running on
Maybe a carbon buildup which will create a hotspot on the piston or underside of a valve.
What plugs are you running? Try dropping a cooler plug in to see if stops the run on?
Cheers Shane
Author:  Minicooper4me [ Wed Apr 06, 2016 7:51 pm ]
Yep, colder plugs have helped me in the past. Also I have used Redex in the fuel tank and gunned through the carby at times. Then a quick flog out the road.
Author:  TheMiniMan [ Wed Apr 06, 2016 9:58 pm ]
Too high an idle & too high compression will help "run-on"
Back off your idle screw a tad & drop your initial ign timing a tad. Maybe 2 or 3 degrees & that should help...
If it does then sneak up your ign a bit by bit but keep dropping idle to suit until you find a happy medium between idle revs & throttle respinse without the run-on when u turn it off
Have u got a compression tester & a taco?
Author:  i got a mini [ Wed Apr 06, 2016 10:21 pm ]
Yep I do it's idling at about 700 atm
