It is currently Tue Jul 29, 2025 1:23 pm
 Post subject: Running on
PostPosted: Wed Apr 06, 2016 6:15 pm
Hey all having a problem with my car when I turn the ignition off it runs for a while then stops. Now I have used a gunson colour tune and it's spot on in mixture and timing is 5 deg at idle and still runs on what causes this any help would be appreciated thanks
 Post subject: Re: Running on
PostPosted: Wed Apr 06, 2016 7:30 pm
Maybe a carbon buildup which will create a hotspot on the piston or underside of a valve.
What plugs are you running? Try dropping a cooler plug in to see if stops the run on?
Cheers Shane
PostPosted: Wed Apr 06, 2016 7:51 pm
Yep, colder plugs have helped me in the past. Also I have used Redex in the fuel tank and gunned through the carby at times. Then a quick flog out the road.
PostPosted: Wed Apr 06, 2016 9:58 pm
Too high an idle & too high compression will help "run-on"
Back off your idle screw a tad & drop your initial ign timing a tad. Maybe 2 or 3 degrees & that should help...
If it does then sneak up your ign a bit by bit but keep dropping idle to suit until you find a happy medium between idle revs & throttle respinse without the run-on when u turn it off
Have u got a compression tester & a taco?
PostPosted: Wed Apr 06, 2016 10:21 pm
Yep I do it's idling at about 700 atm
Users browsing this forum: Goldbrocade_62 and 123 guests
