It is currently Tue Jul 29, 2025 1:11 pm
 Post subject: Windscreen wiper motor
PostPosted: Mon Apr 04, 2016 4:12 pm
An acquaintance has a 68 Mk1 Mini, not a Cooper S, he has a 2 speed, round wiper motor fitted but when turned on, the blades go off the screen at both ends of sweep. I had a look at the gearing and it says 32T (I'm guessing 32 teeth) 105*. I thought the 105* would have been the degrees of sweep, but if this was the case, it would be about 180*
Any suggestions?
johnl
PostPosted: Mon Apr 04, 2016 4:30 pm
He will need to adapt the later wheel boxes to it.
Because the rack stroke is now greater.
