Removing dip stick tube https://ausmini.com/forums/viewtopic.php?f=2&t=92288 |
Author: | minimate [ Sun Apr 03, 2016 1:58 pm ] |
Post subject: | Removing dip stick tube |
What's the best way to remove the dip stick tube from the block. Does it just tap through from the underside or is it threaded in ? ![]() Also what type of gasket glue are people using on the water pump ? Are you best to apply it to both sides of the gasket ? cheers all ! |
Author: | drjbeam [ Sun Apr 03, 2016 2:01 pm ] |
Post subject: | Re: Removing dip stick tube |
Mine sometimes comes out with the dip stick when I check the oil level |
Author: | Mick [ Sun Apr 03, 2016 2:02 pm ] |
Yes, it is just a press fit. Sometimes less than a press as Chris has found. |
Author: | minimate [ Sun Apr 03, 2016 3:38 pm ] |
Ok that's good to hear. I have hit it from the underside with a block of wood and hammer and it's not moved yet, will hit it a bit harder. Any ideas about the water pump gasket fitting. cheers |
Author: | drmini in aust [ Sun Apr 03, 2016 6:33 pm ] |
For the water pump any gasket sealant is fine. [edit] When I say `gasket sealant', I don't mean silicone. I use Loctite/Permatex #3, or Loctite 515 ( a smear). Silicone is for gutters and showers, rofl. |
Author: | TK [ Sun Apr 03, 2016 7:08 pm ] |
waterpump gasket fitting? forget silicone. Aviation gasket cent is the go. The silcone if applied to liberally can come loose and block the radiator cores. |
Author: | drjbeam [ Sun Apr 03, 2016 8:10 pm ] |
http://www.supercheapauto.com.au/online ... mendations I think tk is saying this stuff which I use as well on waterpumps no matter what car it is Its like a dark brown thick liquid with a funny smell |
Author: | drjbeam [ Sun Apr 03, 2016 8:15 pm ] |
drjbeam wrote: Mine sometimes comes out with the dip stick when I check the oil level Just noticed he has a different dipstick to the Leyland engine ones |
Author: | Mick [ Sun Apr 03, 2016 8:16 pm ] |
Yours may be plastic. They're a little bit like that. |
Author: | Phil 850 [ Mon Apr 04, 2016 9:57 pm ] |
My dad used Stag jointing compound 50 years ago when I was a boy. I'm still using it and always had good results. |
Author: | Bill B [ Wed Apr 06, 2016 8:33 pm ] |
Phil 850 wrote: My dad used Stag jointing compound 50 years ago when I was a boy. I'm still using it and always had good results. Ditto. It's like old red lead oxide paint - excellent on parts where water can get under and corrode: like core plugs and oil gallery plugs. Hylomar (with the correct gasket) seems to work on everything. |
Author: | drjbeam [ Wed Apr 06, 2016 9:07 pm ] |
Mick wrote: Yours may be plastic. They're a little bit like that. It is plastic |
Author: | minimate [ Wed Apr 06, 2016 9:41 pm ] |
This dipstick oil tube is steel. It may just have some rust holding it in tight ? I did use Loctite aviation 3 gasket glue on both sides of the gasket (smeared) and seem to have a leak somewhere. I don't think the gasket shifted during application because the bolts screwed in nice and easily. cheers |
Author: | drmini in aust [ Thu Apr 07, 2016 8:26 am ] |
The steel one just taps out, upwards. Even if loctited in, it will tap out. But the plastic (nylon?) ones get brittle, are easily broken if bent at all. |
Author: | miniman269 [ Wed Apr 13, 2016 8:33 am ] |
Gasket goo is all Ive used and never failed Sent from my SM-G900I using Tapatalk |
