https://ausmini.com/forums/
Cooper S screen demist vents
https://ausmini.com/forums/viewtopic.php?f=2&t=92271
Author:  lockwood [ Fri Apr 01, 2016 1:29 pm ]
Post subject:  Cooper S screen demist vents
Does anyone know when the screen demist vents on the Cooper S, the part that is just under the dash rail not the retaining plate on top, were changed from metal to plastic?
Author:  lockwood [ Fri Apr 01, 2016 8:47 pm ]
Post subject:  Re: Cooper S screen demist vents
Someone must have an idea
Author:  Goldbrocade_62 [ Sat Apr 02, 2016 8:14 am ]
My 67 S had plastic
Author:  Bubbacluby [ Sat Apr 02, 2016 8:27 am ]
My april 66 has steel
Author:  Mick [ Sat Apr 02, 2016 1:18 pm ]
June 69 is (Edit:) Steel with a steel heater
Author:  deluxe67 [ Sat Apr 02, 2016 3:01 pm ]
All 3 of my Mini K's had steel ones?
Author:  winabbey [ Sat Apr 02, 2016 4:11 pm ]
My Sept. 1970 MK II S has plastic vents.
On the topic of demister vents it appears the Cooper S did not comply with ADR15 Demisting of Windscreens which came into effect on 1st January 1971. A deflector inserted into and attached to the demister vent apparently solved the problem by directing warm air into areas not previously covered.
