It is currently Tue Jul 29, 2025 11:46 pm
PostPosted: Mon Mar 28, 2016 4:30 pm
Hi, I have just purchased an 81 moke that has been sitting for 15 years. Front disc pistons seem clean but stuck, any advice on freeing them up?
Steve
PostPosted: Mon Mar 28, 2016 4:45 pm
penetrating oil (not WD40) overnight to start with.
PostPosted: Mon Mar 28, 2016 5:08 pm
Don't use compressed air unless you wrap them in rag first. I use a grease nipple in hose hole, pump them out......easy. :-)
PostPosted: Mon Mar 28, 2016 5:23 pm
thanks for that :-)
PostPosted: Mon Mar 28, 2016 6:22 pm
2nd the grease gun approach :-) works a treat usually
Matt
PostPosted: Mon Mar 28, 2016 6:28 pm
Its ok to get grease inside?
PostPosted: Mon Mar 28, 2016 7:47 pm
You will need to clean it all out to put in new seals (and pistons perhaps) anyway.
PostPosted: Tue Mar 29, 2016 7:16 am
and new pads...
PostPosted: Tue Mar 29, 2016 7:48 am
Pads look brand new :-)
PostPosted: Tue Mar 29, 2016 8:15 am
I would assume they'd need overhauling anyway if they're seized. If the pads are newish, just give them a linish and brake cleaner.
PostPosted: Tue Mar 29, 2016 8:23 am
often the pistons are just "cocked" from some dork pulling them back in wrong to effect replacement pads
but most times they`re jammed from grit & rust & crap & years of "lack of maintenance"
grease gun is the go,,, modify the end to fit a brake fitting & Bob`s your Aunt :-)
clean them all out & fit new seals etc & away you go
easy-peasy
PostPosted: Wed Mar 30, 2016 12:10 am
Watch your fingers if using air.
PostPosted: Wed Mar 30, 2016 6:34 am
Not worth reusing if they happen to get contaminated with grease or other fluids :roll:
PostPosted: Wed Mar 30, 2016 8:59 am
Clean the pistons with steel wool or wet & dry paper and inspect.
If the chrome is pitted on the outside, buy new ones.
Originals have a flat machined across the open end, this goes to the top of caliper when assembled. New aftermarket pistons don't seem to have this.
PostPosted: Wed Mar 30, 2016 9:01 am
Thanks Doc, will be giving it all a go on the weekend, and also seeing if I breath life into this moke after sitting for 15 or so years!
Users browsing this forum: Bing [Bot] and 100 guests
