It is currently Tue Jul 29, 2025 11:26 pm
 Post subject: 7.5" disc brake problem
PostPosted: Mon Mar 28, 2016 1:02 pm
G'day everyone,
so I'm taking my van out for the first few drives and I have found that when I apply the brakes (medium to firm pressure) I get a grinding/ticking noise as I come to a stop. Seems to sound like it could be something to do with rotors/pads but thought I would see if anyone had any suggestions, its all new parts and pads are still going through bed in phase. I am going to be getting under the car and checking it out over the next few days before I go driving again. The setup is coopers S 7.5" disc brake kit with hilo's, fast road springs and spax adjustable shocks.
2015 Ducati 899 Panigale
PostPosted: Mon Mar 28, 2016 2:30 pm
Did you clean the discs with brake cleaner and gave them a rub over with emery paper?
PostPosted: Mon Mar 28, 2016 2:32 pm
No I didn't, I thought the bedding in for the pads would do the same for the rotors?
PostPosted: Mon Mar 28, 2016 3:19 pm
They coat the discs in a protective oil to stop them rusting in the box. You really need to give them a good rub over with brake clean and a fresh rag. I usually give them a rub with emery too to help them bed in and not glaze.
PostPosted: Mon Mar 28, 2016 4:05 pm
failing to clean the rotors won't make grinding and ticking noises - take the wheels off and turn the rotors and see what's going on
PostPosted: Mon Mar 28, 2016 5:40 pm
Some wheels barely clear the caliper, near the bleed nipple.
PostPosted: Mon Mar 28, 2016 5:44 pm
If you have the disc shields its not uncommon for small stones to get flicked up between this and the disc. If you take the wheel off and rotate the disc this will be obvious...
Cheers, Ian
PostPosted: Mon Mar 28, 2016 6:16 pm
Are you front wheel bearings adjusted correctly?
Brad
During the day I work on English designed cars & on my own time I work on English designed cars....
PostPosted: Mon Mar 28, 2016 6:20 pm
Quite often you will need to grind a tad off the steering arm to clear the rotor
& also quite often the screw that hold the drive flanges to the rotors are too long & foul on the hub-snout
they`re the 2 common ones that we`ve found over the years
unless you`ve totally stuffed something else up :-) :-) :-)
rip it apart & have a good look"""AS""" you`re doing it, take your time & really Look at everything asyou`re doing it.
you`ll find it :-) it`s just nuts & bolts :-)
PostPosted: Wed Mar 30, 2016 10:23 am
and the winner is -->
took the wheels off this morning and sure enough on the inside of the disc there is a groove right where the steering arm sits (both front wheels), makes sense why it wasn't too bad when the discs were cold but got worse as they were warmed up.
PostPosted: Wed Mar 30, 2016 11:07 am
I had this, if you put the boot ties on the wrong way and forget to put the left-overs into the fold down clips it makes a nice click as well.
Nick
Users browsing this forum: Barkfast and 108 guests
