It is currently Tue Jul 29, 2025 1:12 pm
PostPosted: Fri Apr 01, 2016 10:54 pm
Hi all
Just noticed a cooper s for sale on carsales.com.au (search Morris Mini Cooper)
When I checked the photos of the id plate and engine number it matched the cooper s mk 1 register.
The register says however that the engine number may not be correct however it may well be correct!
Well that's what the photos say
PostPosted: Fri Apr 01, 2016 11:45 pm
Alot of the data on the register has been compiled from people volunteering the information. I am not sure what checks and ballances are carried out to verify it is correct. I personally believe this plate has a few problems. It is entirely hand stamped from a blank plate, the engine number is a few thousand less than others built around the same time and the 2 colours quoted are the around the wrong way compared to the vehicle. Maybe the car had to go back under warranty for an engine replacement and a new hand stamped ID plate was created. Although you would expect a later engine to be reissued. Maybe the colours were changed from red over white to white over red or the person restamping it made a mistake.
PostPosted: Sat Apr 02, 2016 8:38 am
Great response. Always pays to talk to an expert!
PostPosted: Sat Apr 02, 2016 12:07 pm
Plate looks dodgy , should have small 'a' in engine number if factory restamp and engine block has wrong font ,has been restamped
http://www.carsales.com.au/dealer/detai ... 4130/?Cr=0
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Sat Apr 02, 2016 4:37 pm
Just had a quick look, it's a mk1 binnacle with mk2 speedo. Block is stamped too close to the edge. Tellem he's dreamin.
Looks like a nice car but not for that money.
PostPosted: Sat Apr 02, 2016 9:55 pm
Besides the incorrect stamping, other tell tale signs that it's a reproduction ID plate include the missing full stops after "CORRESPONDENCE MUST QUOTE THESE NUMBERS" and "GUARANTEE CEASES ON REMOVAL OF THIS PLATE". Also the silver boarder around the edge of the plate is too thick.
8) In the garage:
1970 Morris Cooper S MK2 | 2010 MINI Cooper JCW Challenge Edition
:( Now with new owners:
1964 Morris 850 Van | 1965 Morris Cooper S MK1 | 1976 Leyland Mini | 1999 Rover Mini Cooper Classic | 2006 MINI Cooper JCW
PostPosted: Sun Apr 03, 2016 4:56 pm
If it is a Cooper S block, why is the PCV coming off the clutch cover - and where does the hose go to if not to the carbs, which also seem to have an odd fuel supply link.
