It is currently Tue Jul 29, 2025 9:33 pm
 Post subject: Lucas Wiper motor
PostPosted: Wed Mar 16, 2016 9:13 pm
Picked this NOS wiper motor up at the local swap meet.
Anyone know what it would be for?
It has screw on terminals and self parking.
The normal exit for the drive rack is blanked by the alloy cover. (normal to a Mini owner)
The main gear housing looks to be the same casting as the Mini one I have.
 Post subject: Re: Lucas Wiper motor
PostPosted: Fri Mar 18, 2016 9:05 pm
Anybody have an info on this wiper motor?
PostPosted: Fri Mar 18, 2016 9:08 pm
googled Lucas DR3A - apparently Triumph TR4A among others... ?
http://www.britishcarforum.com/bcf/cont ... per-motors
PostPosted: Fri Mar 18, 2016 9:11 pm
more... "Wiper Motor DR3 Type with 110 degree sweep. TR4A, TR250 and TR5 as original equipment and TR3A to TR4 as on option. "
PostPosted: Fri Mar 18, 2016 10:02 pm
The Triumph TR4 motor looks the same as the 60's Mini which is also the DR3, or DR3A for the TR4A.
The difference with the one I have is in the number 75597 - different park mechanism, different housing over the gear and screw on terminals, but still a DR3A style.
I believe the park wire coming through the main housing means that it is reverse park, so no good on a Mini.
The different housing over the gear has got me baffled. I did find a similar one on Ebay but the seller did not know what it was from - maybe Morris Minor but I doubt it.
PostPosted: Tue Mar 22, 2016 10:33 pm
I knew I seen a lucas wiper motor model download somewhere http://vitessesteve.co.uk/LucasStuff/LucasManuals with other Lucas stuff
Users browsing this forum: Phil 850 and 116 guests
