su dramas https://ausmini.com/forums/viewtopic.php?f=2&t=92121 |
Author: | nicholasatkins [ Wed Mar 16, 2016 5:17 pm ] |
Post subject: | su dramas |
Hi. Having a few issues getting my 998 setupmwith a single 1.5 su. Idles fine but when you give it some throttle it picks up initially but dies soon after. If i hold the dash pot to restrict air flow it seems fine. Tryed playing with the mixture which did not help much. Should I try a richer needle? Has a fixed AAA needle at the moment. thanks |
Author: | TK [ Wed Mar 16, 2016 5:46 pm ] |
Post subject: | Re: su dramas |
too lean? try running with a bit of choke see what happens. May need a richer needle? |
Author: | carbon [ Fri Mar 18, 2016 7:00 am ] |
AAA needle is likely to be way too rich for a 998. Are you using red spring? |
