It is currently Tue Jul 29, 2025 9:30 pm
 Post subject: su dramas
PostPosted: Wed Mar 16, 2016 5:17 pm
Hi. Having a few issues getting my 998 setupmwith a single 1.5 su. Idles fine but when you give it some throttle it picks up initially but dies soon after. If i hold the dash pot to restrict air flow it seems fine. Tryed playing with the mixture which did not help much. Should I try a richer needle? Has a fixed AAA needle at the moment.
thanks
 Post subject: Re: su dramas
PostPosted: Wed Mar 16, 2016 5:46 pm
too lean? try running with a bit of choke see what happens. May need a richer needle?
PostPosted: Fri Mar 18, 2016 7:00 am
AAA needle is likely to be way too rich for a 998.
Are you using red spring?
Users browsing this forum: Phil 850 and 98 guests
