knuckle joints https://ausmini.com/forums/viewtopic.php?f=2&t=92097 |
Author: | GundyGuy [ Sun Mar 13, 2016 9:21 am ] |
Post subject: | knuckle joints |
Well i have reconditioned my front upper control arm I brazed up the worn end thrust section and milled it back Its perfect now The problem now is the Knuckle Joint When i went to fit the cup it just fell in the hole and was loose as a goose the old one had to be dug out with a screw driver So should it be a push in fit or loose? The part number is RGSV1118 or 21A1163 |
Author: | simon k [ Sun Mar 13, 2016 8:20 pm ] |
Post subject: | Re: knuckle joints |
GundyGuy wrote: So should it be a push in fit or loose? The part number is RGSV1118 or 21A1163 should be a push fit - it won't last long if it can flop around... |
Author: | GundyGuy [ Mon Mar 14, 2016 5:38 pm ] |
Went back to my local mini parts supplier and all his stock was wrong His supplier has dodgy parts Yellow packet with made in Taiwan |
Author: | gtogreen1969 [ Mon Mar 14, 2016 5:57 pm ] |
I was at minisport last year and an upset customer came back in with a set of knuckle joints that were loose. There must be a few bad batches around. |
Author: | GundyGuy [ Sun Mar 20, 2016 4:28 pm ] |
Knuckle joint issue is Fixed The Cup was the wrong OD but right ID So they replaced the cup with a correct size one and Bob's Ya Aunty |
