It is currently Mon Jul 28, 2025 11:42 pm
PostPosted: Thu Mar 10, 2016 3:02 pm
Hi all
I have been searching the threads for Moulded Carpet for an 850 so that it has the bulge for the floor starter.
I have tried Trufit, Knox and TST and none of them have the bulge for the floor starter.
Minispares UK does, but at $261 plus shipping, which is not too bad.
http://www.minispares.com/product/Class ... .aspx|Back to shop
This a multipiece carpet but some of the moulded ones I have seen in posts have been in two piece plus the front wheel arch pieces.
download/file.php?id=541
This is a photo of the TST carpet but they said they don't have the bulge for the starter, but this does.
Any ideas where I should shop.
PostPosted: Thu Mar 10, 2016 3:23 pm
Phil 850 wrote:
Hi all
Newton Commercial in the UK (or via Minisport (in the UK))
PostPosted: Fri Mar 11, 2016 8:35 am
Queensland Moulded Car CarpetsWebsiteDirections
Auto Parts Store
Address: 14 Ferguson St, Underwood QLD 4119
Phone:1300 764 114
Hours: Open today · 7:30am–4:30am
"Let us remove your "SHORTS"
PostPosted: Sun May 01, 2016 5:35 pm
I have been talking to Brad Griegg at Nobull Accessories (Queensland Moulded Carpet) about moulded Carpet for my 850 with the floor starter bulge.
He is confident his carpet has the bulge but at last contact, he was going to check to make sure.
I'll let you know how I get on.
https://nobullaccessories.com.au/produc ... le-carpet/
His site lists 60 to 78 year model.
So it should include the Starter bulge.
PostPosted: Sun May 01, 2016 6:56 pm
all Australian floors have the bulge, but most didn't get a hole drilled in them
PostPosted: Sun May 01, 2016 10:12 pm
If the carpet fits a Leyland rod change, it will have the bulge for the starter. But you will need extra padding under the centre hump, when fitting the carpet to an 850, around the starter area.
PostPosted: Mon May 02, 2016 9:59 pm
Anyone got a picture of a later floor ?
PostPosted: Mon May 02, 2016 10:32 pm
plenty in the members gallery - like this in here - viewtopic.php?f=3&t=90752&start=45
(click for bigger picture)
PostPosted: Tue May 03, 2016 8:27 am
As Simon says all later Oz built cars still had the starter bump in the floor. I found both Tru-Fit Carpets and Knox Carpets are moulded, and fit there pretty good. Just punch a hole for the starter switch.
PostPosted: Sat May 07, 2016 8:43 am
Thanks Simon
Does anyone have a photo of Moulded Carpet fitted to a floorpan as in Simons Photo and where did you buy it. And of course, is it a good fit.
PostPosted: Sun May 08, 2016 10:38 am
Phil 850 wrote:
Thanks Simon
There's a photo of a TST carpet set fitted to a '76 Leyland Mini in this thread.
Although the floor pan is different/later again than Simon's photo.
