It is currently Wed Jul 30, 2025 8:10 am
 Post subject: Temp gauge reading
PostPosted: Sun Mar 06, 2016 8:37 pm
Can anyone diagnose this:
Smiths electric temp gauge reads fine at idle then needle goes to dead cold almost immediately as revs go up from idle?
What shld i be looking at?
Thanks.
Now with 2 extra ports!
 Post subject: Re: Temp gauge reading
PostPosted: Sun Mar 06, 2016 8:54 pm
Possibly the instrument voltage regulator, it is suppose to supply a steady voltage but they are often effected by vibration esp when they are stuffed. Is your fuel gauge also playing up?
User "Wombat" on here used to make a tiny electronic version which is much better than the old mechanical regulator.
Other possibility is the actual gauge has a fault and vibration is causing it to play up.
PostPosted: Sun Mar 06, 2016 9:02 pm
Thanks for the reply.
Thought it might be the stabiliser but the Fuel gauge works fine.
Ill try another gauge and see what happens....
PostPosted: Mon Mar 07, 2016 7:54 am
I guess also check all the earths and connections.
PostPosted: Mon Mar 07, 2016 9:04 am
I assume the coolant level is fine and there are no air bubbles in the system? Thermostat is working too?
PostPosted: Mon Mar 07, 2016 9:44 am
Try the female terminals for tightness on the males of the voltage stabiliser.
PostPosted: Mon Mar 07, 2016 4:58 pm
Is the car moving
1960 Morris Mini Minor
PostPosted: Mon Mar 07, 2016 7:52 pm
minijcar wrote:
Is the car moving
Yes.
PostPosted: Mon Mar 07, 2016 10:30 pm
Also make sure you have the same 10 Volt feed from stabilizer feeding the fuel and temp gauge. Test with an analog Volt meter on both gauges you should have the same 10 V on both. With an analog meter you will find that the voltage flicks up and down and not a steady 10 volts unless you have an electronic stabilizer which should be spot on 10 V. If the voltage goes past 10 Vols get a new stabilizer. With the temp gauge you should get the gauge to go off the scale by grounding the sender wire with key on. I use a gauge tester at the correct scale of resistance through the whole sweep.
"Let us remove your "SHORTS"
PostPosted: Mon Mar 07, 2016 10:33 pm
Thanks!
PostPosted: Tue Mar 08, 2016 8:06 am
Is it wired in the stabilizer the right way
PostPosted: Tue Mar 08, 2016 8:15 am
More info Rob? As far as I know it is, but open to more information.......
PostPosted: Tue Mar 08, 2016 4:34 pm
I think you may have cold air getting into the gauge. Are the corks in the back of the gauge?
Alternatively a bad earth to the engine.
If the reg was going high, the temp would go high.
If the reg dropped out the fuel gauge would drop out.
But i may well be wrong and i'm allowed to be because this is a forum :)
PostPosted: Tue Mar 08, 2016 4:45 pm
You can check this out by taking the car out of gear at speed and coasting. The revs and vibrations drop away, and then there's just the wind getting through the gauge.
PostPosted: Tue Mar 08, 2016 4:59 pm
I remember a well known mini mechanic struggling with this issue to the point of distraction.
He drove a poor van up and down the road in front of my work over and over until he finally relented and turned in to my drive. He didnt want to believe me but was so frustrated he had to begrudgingly give my solution a try....
A bimetal strip deflects on the basis of heating or cooling two dissimilar metals.
It may be something else. Whatever you do dont buy a new sender!
Users browsing this forum: goodie and 98 guests
