Hydrolastic bag replacement https://ausmini.com/forums/viewtopic.php?f=2&t=92034 |
Author: | GundyGuy [ Sun Mar 06, 2016 3:45 pm ] |
Post subject: | Hydrolastic bag replacement |
Well i got 2 used bags that appear OK (Whole rear subframe) Lots of mud in them that i will first flush out they were only recently disconnected so haven't dried out My bag de-laminated around the bottom It was fun getting it out Might even put an endoscope down the hose to give me a fright |
Author: | GundyGuy [ Sun Mar 06, 2016 5:01 pm ] |
Post subject: | Re: Hydrolastic bag replacement |
After inspecting the upper control arm i have found the front thrust face somewhat worn Thus when you assemble the shaft and thrust washers there is endfloat Has anyone done a fix for this My idea was to braze up the end and re-machine it to remove the endfloat All ideas appreciated Also does the thick washer go to the front as my manual tells me nothing and its a Leyland Aust one |
Author: | Mick [ Mon Mar 07, 2016 6:46 pm ] |
Thick goes on the forward end behind the retaining plate. Eccentric groove pushes against the upper arm. |
Author: | GundyGuy [ Sun Mar 20, 2016 4:30 pm ] |
Well the Upper control arm got the Braze and Machine job Worked out perfect |
