Noisy speedo https://ausmini.com/forums/viewtopic.php?f=2&t=92024 |
Page 1 of 2 |
Author: | Phil 850 [ Sat Mar 05, 2016 7:51 pm ] |
Post subject: | Noisy speedo |
I've had a search but not found much ![]() From time to time my speedo "chirps" or "squeals". Is this from the odometer or the drive to the speedo, and more importantly, what is the fix ![]() |
Author: | 9YaTaH [ Sat Mar 05, 2016 8:08 pm ] |
Post subject: | Re: Noisy speedo |
Sounds like the main drive cable and bearing area...how long has it been since you lubed the cable? |
Author: | drjbeam [ Sat Mar 05, 2016 8:11 pm ] |
There's a speedo repair place at Glossop st st Marys about 200 metres back from the Forrester rd lights just on the last bend to them lights http://www.attspeedautoinstruments.com/ I noticed your in western Sydney so shouldn't be far for you |
Author: | drmini in aust [ Sun Mar 06, 2016 5:41 am ] |
I bought a new speedo cable a while ago that was dry as the proverbial inside. Had not a skerrick of lube. Never assume these things are lubricated and ready to fit. And if you run them dry, yes they can squeak. |
Author: | Phil 850 [ Sun Mar 06, 2016 10:24 am ] |
Haven't checked the cable yet but what sort of lube should I put on it ? |
Author: | drmini in aust [ Sun Mar 06, 2016 2:09 pm ] |
A smear of molygrease, leave the top 100mm dry so it doesn't get into the speedo. |
Author: | minijcar [ Sun Mar 06, 2016 5:43 pm ] |
The Doc offers good advice as always. There are however a number of items in the speedo itself thatcan go dry over time. Treat the speedo and cable to a service much the same as you would change the oil from time to time |
Author: | Phil 850 [ Sun Mar 06, 2016 7:45 pm ] |
9YaTaH and minjicar, what are the parts that need lubricating ? I've never pulled a speedo apart before ! |
Author: | 9YaTaH [ Sun Mar 06, 2016 10:05 pm ] |
Phil 850 wrote: 9YaTaH and minjicar, what are the parts that need lubricating ? I've never pulled a speedo apart before ! Don't start now! ![]() The cable should be lubricated with a thin film of Molybdenum Disulphide grease for most of its length...just leave a little each end un-lubed to prevent pumping grease into the speedo head (for example) The rotating magnet assembly bushing within the speedo, AFAIR, has no lubrication(?)... A small amount of Molybdenum Disulphide on the shaft for the Odometer pawl assembly... Most common mistakes home mechs make is opening a Speedo on their workbench with all the magnetic swarf lying around instead of on newspaper spread across the kitchen table!!! ![]() |
Author: | minijcar [ Mon Mar 07, 2016 4:52 pm ] |
Phil If the sqeeking is coming from inside then there will be some wear that grease alone won't fix. If you are going to lubricate the mainshaft you will need to remove and replace two rivets to do so. Have fun |
Author: | 9YaTaH [ Mon Mar 07, 2016 9:27 pm ] |
minijcar wrote: Phil If the sqeeking is coming from inside then there will be some wear that grease alone won't fix. If you are going to lubricate the mainshaft you will need to remove and replace two rivets to do so. Have fun and risk wiping off some of the strength of the rotating magnet at the same time.... If the squeaking is the rotating magnet fouling the drag cup then the speedo needs major surgery.. |
Author: | timmy201 [ Mon Mar 07, 2016 9:31 pm ] |
Mine started to get really noisey... then suddenly quiet and it stopped working completely ! |
Author: | 9YaTaH [ Tue Mar 08, 2016 7:35 am ] |
timmy201 wrote: Mine started to get really noisey... then suddenly quiet and it stopped working completely ! I had an engine that did that once ![]() |
Author: | minijcar [ Tue Mar 08, 2016 4:37 pm ] |
Smiths is the real prince of darkness not Lucas ![]() In fairness, a speedo being showered in dust, oil etc is on a hiding to nothing in a mini. |
Author: | 9YaTaH [ Thu Mar 10, 2016 7:26 am ] |
minijcar wrote: Smiths is the real prince of darkness not Lucas ![]() In fairness, a speedo being showered in dust, oil etc is on a hiding to nothing in a mini. True...but I think for such a mass produced, low cost item, Mini speedos have done really, really well in the reliability stakes ![]() |
