Pressure plate https://ausmini.com/forums/viewtopic.php?f=2&t=92018 |
Author: | Goldbrocade_62 [ Sat Mar 05, 2016 3:34 pm ] |
Post subject: | Pressure plate |
Did Repco make uprated clutch pressure plates or were they based on original fitment? just trying to work out what is in my gt motor |
Author: | Convertible Mini [ Sat Mar 05, 2016 4:42 pm ] |
Post subject: | Re: Pressure plate |
If the clutch did not slip it must be OK. |
Author: | Morris 1100 [ Sat Mar 05, 2016 6:24 pm ] |
The Repco catalogue from 1984 shows the same pressure plate on the Mini and the Cooper S/Clubman GT. (part number deleted) It shows a different driven plate though. |
Author: | Goldbrocade_62 [ Sat Mar 05, 2016 6:58 pm ] |
Convertible Mini wrote: If the clutch did not slip it must be OK. Couldn't tell you I pulled the motor down was debating to use it again or go to a orange one |
Author: | drmini in aust [ Sat Mar 05, 2016 8:39 pm ] |
Measure the thickness of the diaphragm spring and compare it to a blue dot S one. I think same or thicker. I don'thave one here, will check tomorrow. |
Author: | Morris 1100 [ Sat Mar 05, 2016 9:25 pm ] |
I found some more info in some other Repco catalogues. I don't expect anyone is interested though. |
Author: | Goldbrocade_62 [ Sat Mar 05, 2016 9:32 pm ] |
There is a part number on the diaphragm will grab it tomorrow |
Author: | simon k [ Sun Mar 06, 2016 9:03 am ] |
Morris 1100 wrote: I found some more info in some other Repco catalogues. I don't expect anyone is interested though. I'm "reasonably curious"... but you're right, I don't know if it'd stretch to "interested".... |
Author: | drmini in aust [ Sun Mar 06, 2016 2:21 pm ] |
The Repco one I have the spring measures 2.35mm thick. My AP grey dot one is 2.5mm. Both blue dot Cooper S ones here measure 2.10mm. I seem to remember this Repco one was the same thickness as an orange dot one. |
Author: | Goldbrocade_62 [ Sun Mar 06, 2016 5:21 pm ] |
I will measure my orange and repco one |
Author: | Goldbrocade_62 [ Sun Mar 06, 2016 6:21 pm ] |
Can't find my orange must have used it repco one is 2.30mm and a new blue dot is the same i have a light green one that is 2.10mm |
Author: | drmini in aust [ Sun Mar 06, 2016 7:38 pm ] |
Hmmm... the 2 I have here are definitely blue dot? Took one out of an S last week. I throw old green dot ones away...! Unless I am going colour blind and they are green..! ![]() |
