It is currently Wed Jul 30, 2025 8:08 am
 Post subject: Fuel
PostPosted: Mon Feb 29, 2016 1:59 pm
Hi,
I've just bought a 1967 Mini with a 1100s motor in it. Single carby, 1275cc.
Is there any particular fuel I should be running it on, since no one puts lead in it anymore? :lol:
eg Premium Unleaded, regular, 100RON, 98 RON, any additives?
Thanks
 Post subject: Re: Fuel
PostPosted: Mon Feb 29, 2016 2:18 pm
If it hasn't had the ULP conversion then you will need an upper cylinder lubricant. Something like Flashlube http://www.supercheapauto.com.au/online ... mendations or Nulon Lead Substitute http://www.supercheapauto.com.au/online ... mendations . There are a few different ones out there.
With the fuel - you will need to run a higher octane if the engine has a high compression ratio. Lots of people run 98 on their worked engines. Try it on 95 and see how you go.
PostPosted: Mon Feb 29, 2016 2:29 pm
gtogreen1969 wrote:
If it hasn't had the ULP conversion then you will need an upper cylinder lubricant. Something like flashlube http://www.supercheapauto.com.au/online ... mendations But there are a few different ones out there.
Is there an easy way to tell if it has had a conversion?
Is there any problem to just use a 98 rather than a 95, I'm happy to feed it premium stuff.
Thanks
PostPosted: Mon Feb 29, 2016 2:33 pm
Just run 98 if your happy with that.
If you run a too low octane fuel it can knock causing damage to the piston and valves.
You can check for hardened seat inserts using a small flex camera down the spark plug hole or pull the head off.
