Mini window regulators, same as Morris 1100? https://ausmini.com/forums/viewtopic.php?f=2&t=91888 |
Author: | doogie [ Sat Feb 20, 2016 3:24 pm ] |
Post subject: | Mini window regulators, same as Morris 1100? |
Are mini window regulators the same as Morris 1100? Doogie |
Author: | TheMiniMan [ Sat Feb 20, 2016 4:51 pm ] |
Post subject: | Re: Mini window regulators, same as Morris 1100? |
pretty sure they`re Not 1100s have a big plate that bolts to the inside of the door from my memory, i`ll look it up in my books |
Author: | Morris 1100 [ Sat Feb 20, 2016 5:04 pm ] |
The 1100 ones look very similar to the Mini ones, I think the arm length would be the only difference. The part numbers are different. I can take a photo of an 1100 one in an hour or two, I might find a Mini one but that might be a stretch tonight. |
Author: | Morris 1100 [ Sat Feb 20, 2016 5:56 pm ] |
This is a Morris 1100 regulator... ![]() ![]() |
Author: | John Smidt [ Sat Feb 20, 2016 7:19 pm ] |
doogie wrote: Are mini window regulators the same as Morris 1100? Doogie Hi Doogie My Guess Doogie, Is as the Mini R/H regulator is becoming scarce, you are hoping that the 1100 may fit the Mini. it is my experience that the are significantly different in some areas, however the part that you really need can be taken off the 1100 and used on the old worn out Mini one. I am sure you are aware the right hand one is different to the left hand, But even that can be overcome ![]() |
Author: | doogie [ Sun Feb 21, 2016 9:05 am ] |
John Smidt wrote: doogie wrote: Are mini window regulators the same as Morris 1100? Doogie Hi Doogie My Guess Doogie, Is as the Mini R/H regulator is becoming scarce, you are hoping that the 1100 may fit the Mini. it is my experience that the are significantly different in some areas, however the part that you really need can be taken off the 1100 and used on the old worn out Mini one. I am sure you are aware the right hand one is different to the left hand, But even that can be overcome ![]() Hey John Actually it's the opposite, I have a 1100 and a heap on mini regulators, hoping a mini one would fit the 1100. Doogie |
Author: | Morris 1100 [ Sun Feb 21, 2016 10:51 am ] |
Is the regulator stuffed or seized? |
Author: | John Smidt [ Sun Feb 21, 2016 11:04 am ] |
Quote: Hey John Actually it's the opposite, I have a 1100 and a heap on mini regulators, hoping a mini one would fit the 1100. Doogie Hi Doogie, Morris 1100 may be able to help, or our Mutual friend AB if not you can do the reverse of what I suggested Regards John |
