It is currently Wed Jul 30, 2025 11:36 pm
 Post subject: Rocker Shaft Removal
PostPosted: Sun Feb 21, 2016 5:40 pm
Just wondering if its possible to remove the rocker shaft and rockers by slackening off the adjusters fully so that the shaft can be slid out
Or is it a matter of undoing the head stud nuts to remove the posts
1970 MK2 Cooper S
 Post subject: Re: Rocker Shaft Removal
PostPosted: Sun Feb 21, 2016 9:05 pm
It is possible, but much easier to work on with the whole thing removed.
If you remove it when cold with the 5 front head nuts left tight, generally it won't disturb the head gasket.
Just tighten the 4 rear nuts (inners first) to 40 ft/lb when refitting, then re-check the torque on the lot.
