It is currently Thu Jul 31, 2025 12:01 am
PostPosted: Sat Feb 20, 2016 3:24 pm
High heel ninja
Are mini window regulators the same as Morris 1100?
Doogie
PostPosted: Sat Feb 20, 2016 4:51 pm
pretty sure they`re Not
1100s have a big plate that bolts to the inside of the door from my memory, i`ll look it up in my books
PostPosted: Sat Feb 20, 2016 5:04 pm
The 1100 ones look very similar to the Mini ones, I think the arm length would be the only difference.
The part numbers are different.
I can take a photo of an 1100 one in an hour or two, I might find a Mini one but that might be a stretch tonight.
PostPosted: Sat Feb 20, 2016 5:56 pm
This is a Morris 1100 regulator...
PostPosted: Sat Feb 20, 2016 7:19 pm
The Mini King
Doogie
Hi Doogie
My Guess Doogie,
Is as the Mini R/H regulator is becoming scarce,
you are hoping that the 1100 may fit the Mini.
it is my experience that the are significantly different in some areas,
however the part that you really need can be taken off the 1100 and used
on the old worn out Mini one.
I am sure you are aware the right hand one is different
to the left hand, But even that can be overcome :wink:
PostPosted: Sun Feb 21, 2016 9:05 am
High heel ninja
John Smidt wrote:
Doogie
Hi Doogie
My Guess Doogie,
Hey John
Actually it's the opposite, I have a 1100 and a heap on mini regulators, hoping a mini one would fit the 1100.
Doogie
PostPosted: Sun Feb 21, 2016 10:51 am
Is the regulator stuffed or seized?
PostPosted: Sun Feb 21, 2016 11:04 am
The Mini King
Hey John
Doogie
Hi Doogie,
Morris 1100 may be able to help, or our Mutual friend AB
if not you can do the reverse of what I suggested
Regards
John
