https://ausmini.com/forums/
Thin washers under heads of front floor subframe bolts?
https://ausmini.com/forums/viewtopic.php?f=2&t=91765
Author:  Jonnoh [ Sun Feb 07, 2016 10:36 am ]
Post subject:  Thin washers under heads of front floor subframe bolts?
Just curious as to why these are used? Sealing? Prevent movement?
Jon
Author:  DavidE [ Sun Feb 07, 2016 10:56 am ]
Post subject:  Re: Thin washers under heads of front floor subframe bolts?
Jon
I don't know, but as they were there at build, I just put them back on re-installation of my front subframes.
Author:  drmini in aust [ Sun Feb 07, 2016 11:10 am ]
Allows the holes to be bigger for easy alignment.
Author:  Jonnoh [ Sun Feb 07, 2016 4:54 pm ]
Thanks all but forgive me, but how does a thin compressible washer help instead of an 'ordinary' one which would do the same thing? I'm suspicious its to prevent movement because it gets compressed into the shape of the hole when tightened. Having said that one edge was bent upwards so perhaps its to help prevent turning of the bolt similar to a lock tab. Perhaps I would need to ask the engineer.
Jon
Author:  Mick [ Sun Feb 07, 2016 5:21 pm ]
They're called "Panel" Washers and are still available on the shelves at bolt shops and even bolt racks at Autobarn, Supercheap and the like.
They help to spread the load more in thin metal panels as the bolts are tightened up to prevent the metal tearing.
