It is currently Wed Jul 30, 2025 10:30 pm
PostPosted: Fri Feb 05, 2016 6:11 am
Quick one, are the Mini Clubman inner door handles a universal fit for left and right side?
Or are they designed for each corresponding side only.
I'll need a new drivers side soon.
Thanks.
PostPosted: Fri Feb 05, 2016 7:04 am
Im pretty sure you can make them fit either side. Try this:http://minisport.com.au/search/?q=door+handle
Very pricey! :(
Sure there are cheaper ones about
PostPosted: Fri Feb 05, 2016 7:39 am
yes, they are bi-sexual
PostPosted: Fri Feb 05, 2016 2:35 pm
Thanks fellas,
Sweet :)
PostPosted: Fri Feb 05, 2016 7:26 pm
Is there also an MG variant fitted with the same handles, MGB?
Why is it the things that make me tick, are also the things that make me go boom?
PostPosted: Fri Feb 05, 2016 7:37 pm
I have seen them on Australian MGB's as well as Morris marinas, but I think Minis are the most plentiful. have you looked on ebay?
http://www.ebay.com.au/itm/Leyland-Mini ... SwEK9T9niL
PostPosted: Fri Feb 05, 2016 7:43 pm
The MGB handle is still available but it needs some mods to make it fit. Nothing major but not a direct fit.
PostPosted: Sat Feb 06, 2016 8:54 pm
The marina is a different set up not the same as mini on the back
PostPosted: Sun Feb 07, 2016 11:44 am
When you fit it adjust the rods properly or they are prone to breaking...
Alec
Users browsing this forum: Bing [Bot] and 86 guests
