It is currently Thu Jul 31, 2025 7:53 pm
Post new topic Reply to topic  [ 73 posts ]  Go to page 1, 2, 3, 4, 5  Next
PostPosted: Thu May 09, 2013 6:56 pm
Hi guys,
I'm replacing the front wheel bearings at the moment. The front right one went well, it still has a little play though.
The left one needed some persuasion to remove the hub from the bearings. They didn't give up without a fight! Now one of the bearing inners has fused to the hub. I can't get them apart. Any ideas?
PostPosted: Thu May 09, 2013 7:03 pm
I've had that, I think in desperation I used a dremel to cut most of the way through the bearing then split it with a chisel. Potential to damage the shaft so that should be a last resort. If you have access to a proper clamp and press, that would be safest.
PostPosted: Thu May 09, 2013 7:04 pm
Olde skool method-
Angle grind a flat on it, down to within a poofteenth from the shaft.
Then hit the flat with a hammer & cold chisel. Twist off.
Alternative, quicker method-
grind 2 or 3 square sided grooves in it then use a 2 or 3 leg bearing puller. :wink:
PostPosted: Thu May 09, 2013 7:15 pm
Mods rock!
Once they get like that, the drive flange is stuffed.
PostPosted: Thu May 09, 2013 7:24 pm
I agree. Good thing you can still buy new ones (I think?) for drum brakes.
Pity if you have a 997 or 998 Cooper though, as theirs are NLA. However I have reclaimed them in the past by brazing the worn areas up with nickel bronze rod, and re-machining them to fit the bearings.
PostPosted: Thu May 09, 2013 8:51 pm
Oops, I threw out two last month :oops:
Damn, now I feel rotten...
PostPosted: Thu May 09, 2013 8:55 pm
Mods rock!
I think you can get new ones, but if you can reclaim them, then why not? From what we are getting supplied with of late, the old re-built bits would have to be better.
I haven't seen any Cooper Flanges. How are they different?
PostPosted: Thu May 09, 2013 8:59 pm
I've got a picture of a pair here. The discs mount onto the back of the flange, instead of drums mounting on the front. Hence the backs are machined. The difference to the flanges above is marked. Also the studs pass through the flange instead of being mounted on them.
PostPosted: Thu May 09, 2013 9:16 pm
Mods rock!
Gee, they are pretty cactus.
So, just at a quick glance of those, would it be possible to machine some drum brake types to same as these?
Only curious, no, I don't have any Cooper Brakes!
PostPosted: Thu May 09, 2013 10:54 pm
Drum ones are too thin and I think their diameter is a lot smaller (I don't have a Cooper disc one to measure).
PostPosted: Fri May 10, 2013 1:59 am
The Mini King
Good Second hand ones are a good option as well and they are made the way they should be
PostPosted: Fri May 10, 2013 5:14 am
Mods rock!
OK, cheers on that :)
Doh, yes, of course!
PostPosted: Fri May 10, 2013 10:04 am
Well 45 minutes this morning with a BFH and a punch and..
PostPosted: Fri May 10, 2013 10:15 am
Good stuff! :P
PostPosted: Fri May 10, 2013 10:50 am
The Mini King
The part you have on the drive flange Turn it over and check for wear I think it may have some grooves worn in it
Users browsing this forum: Bing [Bot] and 74 guests
