MK1 and MK2 Cooper S Engine Block Differences https://ausmini.com/forums/viewtopic.php?f=2&t=91644 |
Author: | GundyGuy [ Tue Jan 26, 2016 8:35 am ] |
Post subject: | MK1 and MK2 Cooper S Engine Block Differences |
So what are the differences between a MK1 and MK2 Cooper S Engine Block besides the engine numbers ![]() |
Author: | TK [ Tue Jan 26, 2016 9:40 am ] |
Post subject: | Re: MK1 and MK2 Cooper S Engine Block Differences |
Mk 1 has a thin flange and M2 the thick flange (where the block meets the gearbox). |
Author: | drmini in aust [ Tue Jan 26, 2016 10:07 am ] |
And very early Mk1s reputedly were weaker around the centre main. |
Author: | gtogreen1969 [ Tue Jan 26, 2016 10:36 am ] |
drmini in aust wrote: And very early Mk1s reputedly were weaker around the centre main. Do you know roughly up to what engine numbers? eg 9FSAY 38000 |
Author: | rodmac [ Tue Jan 26, 2016 10:58 am ] |
Some early Mk2 Cooper S's (my Mk2 is car number 336 and it has the thin flange block) also had the thin flange block but with the 9F/XE/Y engine number and reportedly some late Mk1's had thick flange blocks. Probably fair to say that sometime in mid 69 there was a transition from thin flange to thick flange blocks - nominally around the introduction of the Mk2. ![]() |
Author: | TK [ Tue Jan 26, 2016 11:17 am ] |
yes this is true Rodmac. |
Author: | sitnlo62 [ Tue Jan 26, 2016 7:56 pm ] |
Keep in mind that the /SA/ refers to the gearbox type, 3 syncro and /XE/ refers to gearbox type 4 syncro. I have also seen a lot of XE thin flange blocks but cant recall seeing a SA thick flange block. Not that it didn't happen, possible I guess. |
Author: | miniron [ Wed Jan 27, 2016 9:32 am ] |
The thick flange MK2 block I have has a stiffening rib adjacent to the dip stick hole. The question is: Do all thick flange S blocks have the stiffening rib? RonR |
