A piece of spring comes out from Oil drain? https://ausmini.com/forums/viewtopic.php?f=2&t=91642 |
Author: | C.RUSLI [ Mon Jan 25, 2016 7:44 pm ] |
Post subject: | A piece of spring comes out from Oil drain? |
Hi guys, Can someone identify this spring? It comes out when I change the Oil. Car has been running usual other than popping out 2 gear on deceleration. Which I suspect just a bad 2nd gear. I just drain my oil and this spring sticking out of the drain... Surely it's not meant to be in there.. Attachment: 20160125_174010.jpg It's about 30mm long 18mm dia Thanks! |
Author: | drmini in aust [ Mon Jan 25, 2016 9:37 pm ] |
Post subject: | Re: A piece of doing comes out from Oil drain? |
Looks like a detent spring, used in all non-rodchange boxes. There are 4 of em. 1-2, 3-4, reverse, and reverse gate. No idea how it could get inside the box, 3 are external fitment except reverse, which is trapped in a blind hole. BTW, diameter is ~8mm not 18. |
Author: | C.RUSLI [ Tue Jan 26, 2016 9:29 pm ] |
I see thanks for the info. Yes it's 8mm Sorry for the typo, was posting with oily hands while servicing ![]() that's correct mine is the older non rod shifter boxes. where can I find where this spring located on the external of the box? |
Author: | drmini in aust [ Tue Jan 26, 2016 9:41 pm ] |
There are 2 hex plugs near bottom, on the clutch side. They are 1-2 and 3-4 detents. The reverse gate lockout one is under a big hex plug (or reverse switch) behind the oil filter. The reverse detent one is inside the casing, cannot be removed until the 1-2? selector shaft and its detent plunger & spring are removed. Then the reverse selector shaft is removed, followed by the reverse detent plunger & spring. |
Author: | kiwiinwgtn [ Wed Jan 27, 2016 8:25 am ] |
Are you using a standard sump plug. Some of the extended ones had a long spring to hold the magnet on. |
Author: | mickmini [ Wed Jan 27, 2016 9:20 pm ] |
Post subject: | Re: A piece of spring comes out from Oil drain? |
<mod edit on the title> Sorry but seeing "doing" coming out with the oil was bugging me. cheers michael |
Author: | gtogreen1969 [ Wed Jan 27, 2016 9:47 pm ] |
mickmini wrote: <mod edit on the title> Sorry but seeing "doing" coming out with the oil was bugging me. cheers michael What's the problem? "Doing" is the sound a spring makes as it shoots across the workshop. |
Author: | timmy201 [ Thu Jan 28, 2016 9:14 am ] |
And also what your phone might think you are typing if you have a "smartphone" |
Author: | drmini in aust [ Thu Jan 28, 2016 10:44 am ] |
gtogreen1969 wrote: mickmini wrote: <mod edit on the title> Sorry but seeing "doing" coming out with the oil was bugging me. cheers michael What's the problem? "Doing" is the sound a spring makes as it shoots across the workshop. That's the sound of it reaching escape velocity, never to be seen again...! |
