https://ausmini.com/forums/
HS2 Carb Float Bowl Lug
https://ausmini.com/forums/viewtopic.php?f=2&t=91610
Author:  GundyGuy [ Fri Jan 22, 2016 5:05 pm ]
Post subject:  HS2 Carb Float Bowl Lug
Just wondering if anyone has successfully fixed a broken Float Bowl Position Lug
This is the little lug on the carb body that the rubber grommet locates in to position the float chamber
I was thinking of tapping a small thread and fitting a small screw
All input appreciated
Author:  Goldbrocade_62 [ Fri Jan 22, 2016 5:57 pm ]
Post subject:  Re: HS2 Carb Float Bowl Lug
I have drilled them before and used a rollpin
Author:  GundyGuy [ Fri Jan 22, 2016 6:20 pm ]
Sounds like a plan
