https://ausmini.com/forums/
Anyone in WA have hydro fluid??
https://ausmini.com/forums/viewtopic.php?f=2&t=91586
Page 1 of 2
Author:  Blunder [ Tue Jan 19, 2016 7:19 am ]
Post subject:  Anyone in WA have hydro fluid??
Hey all
I need some hydro fluid for the weekend does anyone in WA have any or know where I can get some in a hurry??
Guessing I won't be able to get it from Minisport in the timeframe as interstate fluid postage will be slow and I live a little out of metro. Any help or ideas much appreciated..... Prefer to get proper stuff that use the 50:50 mix option.
Ta
Author:  Babes [ Tue Jan 19, 2016 4:13 pm ]
Post subject:  Re: Anyone in WA have hydro fluid??
Yes I have some
Author:  simo74 [ Wed Jan 20, 2016 6:50 am ]
Wow the boys in Perth have woke up, have't seen much of Babes lately, next thing we know boomini will give us an update on his supercharger !!
Author:  simon k [ Thu Jan 21, 2016 6:29 pm ]
castrol antifreeze concentrate
Author:  goodie [ Fri Jan 22, 2016 7:00 am ]
+1 , i done a 70/30 mix with distilled water :wink:
Author:  drmini in aust [ Fri Jan 22, 2016 7:41 am ]
I use 50/50.
Author:  jme [ Fri Jan 22, 2016 1:02 pm ]
+2 for Castrol Anti-Freeze. I use 50/50 mix, the benefit of using anti-freeze in your suspension is that it will stop your radiator from freezing. No, really... it says so on the bottle :)
Author:  Blunder [ Fri Jan 22, 2016 5:37 pm ]
Where can I get that specific one?? I have found radicool but not the one mentioned..... Thanks
Author:  goodie [ Sat Jan 23, 2016 7:40 am ]
I think from memory i brought it from Supercheap.
Author:  drmini in aust [ Sat Jan 23, 2016 8:38 am ]
Nulon or Valvoline green glycol concentrate is ok too. Just don't but any pre-mixed lollywater!
Author:  GundyGuy [ Thu Mar 10, 2016 6:12 am ]
I saw at the local Mini place their mix was 14 parts water, 6 parts methanol, 5 parts glycol
So whats the Methanol for
Just another antifreeze ingredient
I want to make my own brew
Author:  phillb [ Thu Mar 10, 2016 11:42 am ]
Yes I have also used 1 part nulon concentrate to 1 part distilled water. Basically a more concentrated mix of coolant.
Edit: another option I have heard is methylated spirit instead of water. Maybe this would lower the freezing point further. Perhaps if you lived in Alaska this may be a consideration.
Author:  boomini [ Thu Mar 10, 2016 2:22 pm ]
Yes us wa boys are still here... just busy with making our minis fat
Author:  GundyGuy [ Thu Mar 10, 2016 5:06 pm ]
I found this info as to what was in this fluid
49% alcohol
49% distilled water
1% triethanolamine phosphate
1% sodium mercaptobenzothiazole
Author:  simon k [ Thu Mar 10, 2016 7:01 pm ]
I actually use the antifreeze straight up... whether or not that's a good thing I don't know
49% alcohol
49% distilled water
that's the original recipe... alcohol to stop it freezing, water to make it cheaper, the other 2 ingredients (dunno which is which) is rust inhibitor and something to stop the mechanics drinking it
