Flywheel https://ausmini.com/forums/viewtopic.php?f=2&t=91557 |
Author: | r32 [ Sat Jan 16, 2016 3:39 pm ] |
Post subject: | Flywheel |
What should be the max and min clearance of the crank c washer and the flywheel be |
Author: | TheMiniMan [ Mon Jan 18, 2016 7:26 pm ] |
Post subject: | Re: Flywheel |
as long as the flywheel doesn`t butt-up against it & squeez the primary gear gap/clearance shut all should be well an easy test is to fit it all up , tighten the flywheel up leave the tin-hat off & get a long thin screw-driver or seal pick or whatever & stick it through the starter motor hole, right into the inbetween the back of the flywheel & loose backing plate to make sure the clutch plate still turns freely if it don`t turn then you have a problem |
