It is currently Thu Jul 31, 2025 5:28 pm
 Post subject: Flywheel
PostPosted: Sat Jan 16, 2016 3:39 pm
What should be the max and min clearance of the crank c washer and the flywheel be
 Post subject: Re: Flywheel
PostPosted: Mon Jan 18, 2016 7:26 pm
as long as the flywheel doesn`t butt-up against it & squeez the primary gear gap/clearance shut
all should be well
an easy test is to fit it all up , tighten the flywheel up
leave the tin-hat off
& get a long thin screw-driver or seal pick or whatever & stick it through the starter motor hole, right into the inbetween the back of the flywheel & loose backing plate
to make sure the clutch plate still turns freely
if it don`t turn then you have a problem
