It is currently Fri Aug 01, 2025 1:18 pm
PostPosted: Sat Jan 16, 2016 9:10 am
Has a Mk 1 Cooper S distributor (no vac advance). I retarded the timing a fair bit when running low octane fuel but forget where it was. Running 98 RON fuel.
Thanks
Mikal
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Sat Jan 16, 2016 9:39 am
Loosen the dissy clamp nut, start the engine and turn the dissy slowly to advance the timing (anti-clockwise I think it is, I haven't done this for a while on a Mini) until you get the engine revs to rise and pick up to a peak, then slightly back off (turn the dissy back to retard it just a small amount). Re set the idle speed on the carb if necessary, then take it for a run and check that it doesn't ping under load. If it does, retard the dissy timing a slight bit more, and re test when driving.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Sun Jan 17, 2016 10:30 am
Thanks Slide, that did the trick. Advanced to max rpm then backed off slightly. Was hard to start so back off a little more to cure that. Road test was good (as much as you can do in the 'burbs' anyway). Couldn't detect any detonation under hard acceleration (allowing for induction noise and noisy exhaust!). I think all is good. Thanks again..
Mikal
67 Deluxe
Dry suspension
