Hi all,
Clutch went recently...rusty fluid leaking out of slave cylinder. Removed tube between master and slave cylinder and trying to get hose to slave cylinder off the large locking nut. Had to remove engine brace to get in there to have a look! Can't get any purchase to get the hose off the slave cylinder with it in attached the engine bay.
The hose is turning when I turn the locking nut, so tried putting bleed nipple with same thread to hold hose fitting while turned locking nut.....no go as scared will bust the nipple off in the thread.
The big problem is that there is a tab under the locking nut on the fixed bracket which is supposed to hold the hose so you can unscrew the locking nut, but the hose is just turning. Only idea I can think of is jack the car up, stick a bloody long screwdriver up from under the car to jam the hose nut and get a spanner on the top locking nut.....bloody hard to get to the hose where it goes through the bracket as the bracket has a lip around it.......
It looks impossible even to put a flare spanner on the hose fitting because of this lip...
Anyone with a brilliant idea or experience with this particular.....design complexity?
