It is currently Sat Aug 02, 2025 8:36 am
 Post subject: Wheel Bearings
PostPosted: Sat Jan 09, 2016 3:26 pm
Hi Guys,
So, been looking at some rear wheel bearings, i bought the tapered type... however i have the old ball bearing type bearings in the hub and according to a diagram they had a potentially different arrangement with the handbrake....
Question, can i simply fit the tapered bearings into a standard ball bearing rear housing? or are there different types? will it have any affect? is there anything special i would need to do if i did this? or just standard replacement
Evan
 Post subject: Re: Wheel Bearings
PostPosted: Sat Jan 09, 2016 6:58 pm
ewatkins wrote:
Hi Guys,
Evan
I put Timken rollers in my matic's std rear hubs before Xmas, no probs. Stock handbrake... ???? :?
Rear Mini hubs (Oz ones anyhow) are all the same.
I'd say you have a UK Rover diagram they do have a different cable setup.
