Wheel Bearings https://ausmini.com/forums/viewtopic.php?f=2&t=91493 |
Author: | ewatkins [ Sat Jan 09, 2016 3:26 pm ] |
Post subject: | Wheel Bearings |
Hi Guys, So, been looking at some rear wheel bearings, i bought the tapered type... however i have the old ball bearing type bearings in the hub and according to a diagram they had a potentially different arrangement with the handbrake.... Question, can i simply fit the tapered bearings into a standard ball bearing rear housing? or are there different types? will it have any affect? is there anything special i would need to do if i did this? or just standard replacement Cheers, Evan |
Author: | drmini in aust [ Sat Jan 09, 2016 6:58 pm ] |
Post subject: | Re: Wheel Bearings |
ewatkins wrote: Hi Guys, So, been looking at some rear wheel bearings, i bought the tapered type... however i have the old ball bearing type bearings in the hub and according to a diagram they had a potentially different arrangement with the handbrake.... Question, can i simply fit the tapered bearings into a standard ball bearing rear housing? or are there different types? will it have any affect? is there anything special i would need to do if i did this? or just standard replacement Cheers, Evan I put Timken rollers in my matic's std rear hubs before Xmas, no probs. Stock handbrake... ???? ![]() Rear Mini hubs (Oz ones anyhow) are all the same. I'd say you have a UK Rover diagram they do have a different cable setup. |
